FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Panther Blank Firer
Post new topic   Reply to topic    Armortek Forum Index -> Official Technical Advice from Armortek
View previous topic :: View next topic
Author Message
PostPosted: Wed May 21, 2008 10:14 am    Post subject: Panther Blank Firer Reply with quote
The blank firer unit is mounted on a special spacer block in the Panther, and is secured using M6*40cap head screws. These screws are designed to engage with the mag house by a minimum of six threads. Due to a variation in flange thickness on the mount, there is a possibility that some builders may find that these screws are not long enough to achieve this minimum requirement. Please contact Armortek for replacement longer screws should this be the case.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Armortek Forum Index -> Official Technical Advice from Armortek All times are GMT + 1 Hour
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
