FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Sd Kfz 221 mit 2.8cm spzb41
Post new topic   Reply to topic    Armortek Forum Index -> Sdkfz 222
View previous topic :: View next topic
Author Message
martin pitcairn
PostPosted: Fri Jan 15, 2010 7:43 pm    Post subject: Sd Kfz 221 mit 2.8cm spzb41 Reply with quote
I have finnaly got the basic turret and gun layout done for this, if i can find out how to post pictures i will show what i have done. be aware it is not the skill level of the king tiger or panzer iii builders, but just an attempt for something different!
Back to top
PostPosted: Sat Jan 16, 2010 10:40 pm    Post subject: Reply with quote
Martin, sign up to PhotoBucket.com - it's free.
Upload the photos from your PC to your PhotoBucket album and once they are there, to the side of each photo, in a box marked "Share this image", there is a link for "IMG Code".
Copy everything in that window, between and including the [IMG] and [/IMG] tags, into your message on this forum.
When you click on the Preview button, you should see the image appear in your message.
Any problems, drop me a PM.
Back to top
PostPosted: Sat Jan 16, 2010 10:51 pm    Post subject: Reply with quote
Martin,
Would like to see what you've done as well.
Back to top
martin pitcairn
PostPosted: Mon Jan 18, 2010 9:07 pm    Post subject: Reply with quote
Lots of stuff to do, this is just the basic shape and size, please give me your view both good and bad as i want this to look right. i have 2 of these 222's the first will be a normal 222 but with the front armoured ram.
Back to top
Ad Wouterse
PostPosted: Mon Jan 18, 2010 11:15 pm    Post subject: Reply with quote
Hi Martin,
Great pics of this rare variety of the SdKfz.
Have you used the Dragon Panzerbüchse 41 for your conversion or is it scratchbuilt ?
Are you going to "downgrade" the 222 to a 221 as well ?
_________________
Ad
Back to top
martin pitcairn
PostPosted: Mon Jan 18, 2010 11:24 pm    Post subject: Reply with quote
I wish it was scratch built, but no it is the Dragon 41. It was the gun that gave me the idea. One of the issues i have is that every type, configeration of turret and chassis seems to be used or retro fitted. there does not seem to be any real plans or scale drawning. there is a new book out from tankograd.com on the 221/222 etc and i am waiting for that to see what that shows.
Back to top
martin pitcairn
Back to top
Ad Wouterse
PostPosted: Tue Jan 19, 2010 7:36 pm    Post subject: Reply with quote
Hi Martin,
In the book Panzerspähwagen by Uwe Feist and Robert Johnson, published by Ryton Publications, there are some pages dedicated to the SdKfz 221 with a Pb 41.
_________________
Ad
Back to top
martin pitcairn
PostPosted: Mon Jan 25, 2010 9:49 pm    Post subject: Reply with quote
Ad, i took your views on board and desided that you had a point, much as i thought it would be a big job. It turned out to be much easier than i thought! When i looked at converting the engine compartment back to the High back model, i thought it would be difficult to get the angles right and spent a day trying to work it out and then my brian woke up and the angle were realy easy and the shapes were easy. i was making it too complicated in my mind. i will post pictures later of the back once the primer dries. i now plan to remove the front double visors and replace with the old single one. i am not sure what else i will do then, so more ideas please.
Back to top
martin pitcairn
PostPosted: Mon Jan 25, 2010 11:08 pm    Post subject: Reply with quote
Back to top
Ad Wouterse
PostPosted: Tue Jan 26, 2010 9:24 pm    Post subject: Reply with quote
Hi Martin,
There are various things you may want to change, it all depends on how far you want to go.
Do you need pictures on the 221 (with PB 41) ? Just send me your e-mail address per PM and I can mail you some.
_________________
Ad
Back to top
Display posts from previous:
Post new topic   Reply to topic    Armortek Forum Index -> Sdkfz 222 All times are GMT + 1 Hour
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
