Jeffs 25 pounder
Jeffrey Goff
Has liked: 19 times
Been Liked: 133 times
Re: Jeffs 25 pounder
Post by Jeffrey Goff » Sun Apr 07, 2019 6:14 pm
last of the brackets for the rear of the shield made and fitted, fuse indicator represented by a piece of brass strip, and housed in its canvas case, still have lots of leather straps to make, then on to the front of the shield
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Wed Apr 10, 2019 7:42 pm
finished detailing rear of the shield, and made a start on the front, the aiming poles and brackets took a bit of head scratching, to get them to be functional, just the white numbers and banding to do, also made some of the tools, and remade the brackets for the pickaxe head
regards Jeff
Has liked: 365 times
Been Liked: 900 times
Post by Stephen White » Wed Apr 10, 2019 8:06 pm
Amazing Jeff, always look forward to the next instalment of magic. Stephen
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Thu Apr 11, 2019 3:27 pm
Thanks Stephen, not many updates to come, all the main elements completed, just straps and a couple of tie downs to do, finished the aiming poles, these have steel shafts and arms, used the kit shovel head but with a wooden handle, and fitted one of Dave's drag ropes
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Sat Apr 13, 2019 4:36 pm
The 25 pounder is now finished, although there might be an update if an ongoing project comes to fruition, its has been a very enjoyable build, light and easy to work on, and plenty of scope for detailing, plus plenty of help and encouragement from the forum.
Anyone guess what my next project is
thanks for looking
regards Jeff
Has liked: 873 times
Been Liked: 2363 times
Post by Phil Woollard » Sat Apr 13, 2019 4:55 pm
I can see some weathering needed on that beautiful piece! Like the chassis behind to.
Post by Stephen White » Sat Apr 13, 2019 5:57 pm
Jeff, this is one of those threads that really has been worth following. I've not only enjoyed watching an outstanding model being built but have picked up some new techniques along the way. I've already invested in an engraving machine, inspired by your examples of what can be achieved. Thanks for all your posts.
I suppose the obvious answer to your question is the limber but is that too easy? A Pheasant? Whatever, it'll be worth following.
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Fri Jul 26, 2019 7:39 pm
in my last post I mentioned there might be an update, during the build of the ranging apparatus I asked if anyone knew how to add the ranging scale to the cone, well one of our furum members from the other side of the world, Liam Mahoney took up the challange, and today I received the first sample, and it is fantastic, it will be laser engraved on steel shim, and will need to be trimmed to size and fixed, I am very pleased with mine, if anyone is interested in one let me know, cost will be approx £16 plus postage
regards Jeff
Has liked: 263 times
Been Liked: 928 times
Post by Vince Cutajar » Fri Jul 26, 2019 8:43 pm
That really looks great.
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Sat Jul 27, 2019 4:54 pm
Thanks Vince but Liam takes the credit, I thought I would add some more detail for whats on offer, the range scale will be produced by laser onto steel shim, this will need to be trimmed to size and rolled around the plain alloy cone on the Armortek part EJ0263 and fixed in place, the sample that I tested had a spelling mistake, ( no E in range) this will be corrected and slightly thinner shim used to make it easier to roll
a couple of pictures of my 25 pounder before and after fitting the range scale
postage will be from the UK
regards Jeff
Marcus Kwa
Been Liked: 25 times
Post by Marcus Kwa » Sun Jul 28, 2019 10:16 am
Awesome!! Whow, that looks fantastic Jeff!! But me up for two!
Does Liam also do the id plates and warning plates for the 25 pdr?
Marcus
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Sun Jul 28, 2019 10:57 am
Hi Marcus, will let you know when they are in, if Liam can produce this level of detail on the range scale then who knows what is possible, it would be great to have raised wording on the Id plaques, I will ask the question, if achievable in 1/6th that opens up a new level in super detailed parts
Regards Jeff
Robert Reid
Has liked: 67 times
Been Liked: 294 times
Post by Robert Reid » Sun Aug 04, 2019 12:05 am
Jeff:
That ranging scale has been at the top of my list... and I have been trying to figure out how to do one with my simple 'trophy engraving' machine... but the setups were just too daunting.
I want one of those for sure!!!!
Do they also get used on the 17 pounder? Somehow I don't think so. But if they do... I think I need two!
RPR
Been Liked: 119 times
Post by Robert E Morey » Sun Aug 04, 2019 2:57 am
Jeff,
Fantastic 25pdr. Hard to tell is not the real thing. I hope your next project is another military piece or vehicle. I love following your progress. Looks like the engine in background could use a little attention. Hope your next is another Armortek!
Robert Reid
Has liked: 67 times
Post by Robert Reid » Mon Nov 25, 2019 12:27 pm
Jeffrey Goff wrote:
Fri Apr 05, 2019 4:39 pm
Hi Michael, thanks for the information, I had missed making the sight clinometer pouch, do you have a picture of the pouch or container for the fuse indicators, that was stored on the top right rear of the shield, above the dial sight.
a bit more completed, made the Apparatus, Illuminating, sights No5, that bolts to the slotted bracket on the bottom left rear of shield, made from steel with brass hinges, also made the two canvas bags that hold the barrel pull through' s
regards Jeff
Hey Jeff.... what is 'in' this box? Looks like a wiring harness of some kind? Something to do with trailering? Hydraulic lines for recharging the cylinders? Communications equipment?
Going to make up the box on my Thursday 'day off.'
Also, what does the plaque above it say?
RPR
cron
