Martin's Jagdpanther
Martin Hofmann
Has liked: 36 times
Been Liked: 483 times
Re: Martin's Jagdpanther
Post by Martin Hofmann » Tue Nov 14, 2017 5:40 pm
I also have done some progress with the roof plate and the covers.
Here some photos......
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Fri Nov 17, 2017 3:46 pm
Now the roof get some rain protection at the openings with their welds and a rough surface to simulate the rolled heavy plates.
Also the covers gets some o-rings for sealing. The inner plate against the seal will come soon.
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Tue Jan 23, 2018 5:33 pm
Now i start the build of the exhausts with the Flammenvernichter. Here comes some photos of the parts before soldering.
Regards Martin
Has liked: 262 times
Been Liked: 88 times
Post by Christoffer Ahlfors » Tue Jan 23, 2018 8:05 pm
Gee!
I have never seen anyone attempt the "turbines" in metal before. How did you do it? :shock:
/Chris
Been Liked: 416 times
Post by simon_manning » Tue Jan 23, 2018 11:14 pm
very nice, some good building going on here, i like the exhausts, regards simon manning.
Michal Matata
Has liked: 4 times
Been Liked: 92 times
Post by Michal Matata » Thu Jan 25, 2018 9:46 am
Hi Martin,
Very nice work. Which a sheet thickness do you use for the turbine? It seems to me a little bit massive. In real turbine it was from 3-4mm. I used the 0,7mm sheet for the pipes and 0,4mm sheet for the turbines. I used only the brass sheet because of the welding.
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Thu Jan 25, 2018 5:55 pm
Hi Chris, Simon and Michal,
thank you very much for your nice words.
Chris: the turbines of Simon are also metal ( i think steel ) and they was the inspiration of my turbines.
Simon: your turbines are very impressive and also looking very good!!! - like all your work here!!!!
Michal: i use an aluminium sheet of 0,5 thickness for the turbines.
Here are some photos of the collar and the distance plates for the holder to the hull.
Regards Martin
Been Liked: 115 times
Post by Robert E Morey » Sun Feb 04, 2018 9:46 pm
Beautiful work Martin - your exhausts are work of art! Lovely job!
Rolf Mönke
Been Liked: 1 time
Post by Rolf Mönke » Tue Feb 06, 2018 8:58 am
Gut geworden!
Greetings from Hamburg
Rolf
bosswilli-hh@gmx.de
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Tue Feb 06, 2018 5:15 pm
Hi Bob,
Hi, Rolf,
thanks for the compliments.
But i am not able to solder the aluminium parts. All done new - in steel :evil: :evil: :evil:
Here is the result of the first soldered tubes and tubines.
Not so exactly like Simon and Michal, but with some damages - it was war!!!
Regards Martin
Post by simon_manning » Tue Feb 06, 2018 6:23 pm
well done martin, these are difficult parts to make, regards simon,
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Fri Feb 09, 2018 4:08 pm
Hi Simon,
you are absolut right - hard to make this parts, but i like it after priming.
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Mon Feb 19, 2018 4:18 pm
And here comes the parts after painting and welding.
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Thu Feb 22, 2018 4:35 pm
in the mean time i had some more progress at the gear case and the return roller.
Here are some photos........
Regards Martin
Marco Peter
Has liked: 235 times
Been Liked: 308 times
Post by Marco Peter » Wed Apr 04, 2018 2:51 pm
What do you use to make the surface so nicely 'cast'-looking? :-)
'Konan', my Tiger 1 Mid!
'Gunther', my Panther G!
cron
