Panther Jagdpanther tracks
vincent hung shu yue
Post by vincent hung shu yue » Fri Aug 28, 2015 8:13 am
I plan to upgrade my panthers and Jagdpanther track as above. Which is fit for Armortek without any modification. Will come with all pins and collars. I still don't know the cost. Each set will have 200 tracks . The estimate cost will around 500 pounds. The material is steel and iron . Any body who is interest can PM me. Only 20-25 sets will be produced. And I need 7 sets only.
Vincent
Kent Wiik
Has liked: 6 times
Been Liked: 73 times
Re: Panther Jagdpanther tracks
Post by Kent Wiik » Fri Aug 28, 2015 1:44 pm
Hi Vincent,
Nice links and an opportunity to good to be missed, pm sent.
It´s all in the details!
Post by vincent hung shu yue » Sat Aug 29, 2015 5:17 am
Hello all
Thank you for your interest. I had received your PM. I will put you down on the list. But I take time to meet the guys in Shenzhen. It take time..... And I try to make it perfect, before my commitment, any suggestion of any improvement are welcomed ..The pin will like this...
Vincent Hung
Drawing of the pin and collar
Post by vincent hung shu yue » Sat Aug 29, 2015 6:29 am
The inner diameter will little bit small so you can fix it with a hammer and it wouldn't come out of the pin.
Collar drawing
Kent Wiik
Has liked: 6 times
Post by Kent Wiik » Sat Aug 29, 2015 7:45 am
Hi Vincent,
Your links and pins look great, the guide horns with the holes are ace and so are the chevrons.
Talking about the chevrons...the squares seen on the outer pairs I guess is from the casting process and for us to remove?
No big deal and an easy fix with a dremel and a file.
You asked for suggestions of any improvement and if possible add the raised edge at the ends seen here in this photo:
Thanks for taking on the task making as accurate as possible and suitable for driving fitting the Armortek Panther/Jagdpanther tanks, much appreciated.
Post by vincent hung shu yue » Sat Aug 29, 2015 9:31 am
Hello Kent
The square seen will be removed. I appreciate your suggestion. And I will follow, hope we can have a nice and accurate track link.
Cheer
Vincent
Fabrice Le Roux
Been Liked: 1 time
Post by Fabrice Le Roux » Sun Aug 30, 2015 12:32 am
Hi Vincent,
"Steel and iron" tracks would be a great Panther upgrade. Are they investment ( lost-wax ) castings or die-castings?
Fabrice
Post by vincent hung shu yue » Sun Aug 30, 2015 6:06 am
Hello Fabrice
Die casting.
Vincent
Kent Wiik
Has liked: 6 times
Post by Kent Wiik » Sun Aug 30, 2015 10:19 am
Hi again Vincent,
One other thing that come to my mind is if would be possible to add the casting letters?
Different foundry's had their own letters/numbers and here is a good photo of one:
It says:
cbV
MV
Never mind the grousers, that would be much to complicated but the cast letters would be nice.
Per Sonnervik
Been Liked: 1 time
Post by Per Sonnervik » Sun Aug 30, 2015 2:17 pm
Hi Vincent,
Very nice initiative and interesting subject. I´m interested in a set (I´ve sent you a pm). Just one question - what dimension do you have from center of one trackpin to the other (the CC between trackpins)? Should be 155/6 = 25,8 mm in 1/6 scale.
Also heads of trackpin´s should not be flat but rounded - if possible.
/Per
Post by vincent hung shu yue » Sun Aug 30, 2015 3:58 pm
Hello Per
I will try this if they can do it this way. Can you kindly supply me a drawing of the in and collar.
Vincent
Post by vincent hung shu yue » Sun Aug 30, 2015 4:28 pm
Hello Per
1 mm wider than Armortek original.
Vincent
Post by vincent hung shu yue » Sun Aug 30, 2015 4:31 pm
Hello Pet
See the difference.
Comparison of Armortek and new one
mark lawson
Has liked: 1431 times
Been Liked: 168 times
Post by mark lawson » Mon Aug 31, 2015 9:25 pm
Vincent, I have sent you a PM to register my interest in these tracks
RAG Militärmodellbau
IG Militärmodellbau
Post by vincent hung shu yue » Tue Sep 01, 2015 6:39 am
Hello Mark
Yes ! I have received your reservation.
I will let all of you know if there is any progress..
Vincent
cron
