• In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
  • Most users ever online was 371 on Mon Sep 03, 2012 7:49 pm
  • Users browsing this forum: No registered users and 0 guests
Tiger 1
T1 overhaul
Re: T1 overhaul
Postby Mick Coleman » Sat Jun 02, 2012 7:50 am
Ok, did some more work on the old girl today. Now we have motion, sound (always on, I need to work out how to fix) turret turn and gun elevation. I've started detailing her now. I've also got to hook the smoke up, almost done! :wink:
Armour:
1:6 Challenger 2
1:8 King Tiger
Please visit: Large scale R/C tanks Australia on Facebook.
Mick Coleman
Re: T1 overhaul
Postby Mick Coleman » Sat Jun 02, 2012 11:36 am
We now have smoke.
Proportionate smoke.
http://youtu.be/gQf-CJotdhg
Turret and gun elevation video.
http://youtu.be/L_FO3xkh3Q0
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby leesellars » Sat Jun 02, 2012 3:44 pm
Hello Mick
The early sound systems where very tempamental. The sound sometime always on and sometimes it doesnt come on at all. also it is not proportional.
lee
Allways look as if your busy.
If its not broke dont fix it.
Ich Hatt Einen Kameraden[
/color]
leesellars
Re: T1 overhaul
Postby Adrian Harris » Sun Jun 03, 2012 12:00 am
> Also does it have a volume? Things as loud as buggery.
Yes, but buried inside.
You need to remove the four screws from the corners of the plastic case, then remove the lid and extract the circuit board from the box.
At the heatsink end of the PCB, you should see two small black square parts with what looks like a white arrow in the centre. One is marked VolEng, I couldn't read what the other said.
These are rotary resistors and control the volume of the engine sounds (VolEng) and other sounds. With a small flat bladed screwdriver, you should be able to rotate the central white hub to adjust the volume of the sounds. The central section will only rotate for a certain arc - about 8 o'clock to 4 o'clock - not all the way round.
Be very careful not to let any part of the PCB contact anything or it'll go really quiet really quick :wink:
[Sd.Kfz 222] [Sd.Kfz 7] [Flak 36] [PzKpfw III] [Stug III] [PzKpfw IV] [PzKpfw VI Early] [PzKpfw VI Mid]
[Sherman M4A3] [Sherman Firefly VC] [M2 Halftrack] [M3 Halftack]
Re: T1 overhaul
Postby Mick Coleman » Sun Jun 03, 2012 12:36 pm
Thanks lads. :wink:
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Mick Coleman » Fri Jun 08, 2012 11:20 pm
Lads will a new set of T1 tracks stretch at all during the first few hours of run time? Also what's the best primer and paint for an Armortek?
Thanks Mick
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Adrian Harris » Sat Jun 09, 2012 12:13 am
They won't stretch per se but any burrs or other high spots from the casting will get flattened out, so they do grow a little.
I'll leave the paint advice to the professionals :oops:
Re: T1 overhaul
Postby Mick Coleman » Sun Jun 10, 2012 11:54 am
Took the old girl for a good run today and she went very well. Next step is to replace all electrical connectors with t-plugs and the like. Very happy. :wink:
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Mick Coleman » Tue Jun 12, 2012 8:48 pm
Took her out last night and noticed a sound that sounds like gears slipping when she turns, might be a loss pinion gear or something? I'll check that out during the week.
Also what do you recommend to use as a primer and top coat?
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Mick Coleman » Sun Jun 17, 2012 5:58 am
What's the best way to get the drive sprockets off one of these old girls?
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Mick Coleman » Sun Jun 17, 2012 10:51 am
Also whats the best way to adjust the suspention?
Thanks Mick
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Adrian Harris » Sun Jun 17, 2012 12:43 pm
G'day Mick.
Does she have taper lock bushes or the older, three hole plate jobbie ?
For a taper lock bush, undo the two opposing grub screws and then slowly insert on into the unused hole. This should expand the taper lock bush slightly and allow it to release from the drive shaft.
For the older style sprockets, there are two M4 CSK bolts which hold the retaining disk to the sprocket casting, and a central M5 CSK bolts which holds the disk (and sprocket) to the drive shaft.
One both methods there is also a small square key which fits into a keyway machined into both the drive shaft and the sprocket or taper lock bush.
On the older models there are two areas to look at if the drive isn't working correctly.
The first is the motor mounting. On the very first Tiger's, the motors bolted to the floor in two places. This meant that hull flex could affect the meshing of the motor and main drive gears. There is an upgrade available, so that the motor can be bolted to the hull side using a large round bush, in place of the forward floor mounting. This should eliminate any meshing issues.
The second is more serious and is because the original main drive gears were made from two parts - the drive shaft and gear itself. Under heavy load, it was found that the Parvalux motor had the power to twist the shaft away from the gear. This leads to total loss of drive on the affected side, so this doesn't sound like your problem. Again, there is an option to retro fit new Tiger main gears, as these are now machined from a single piece of steel, so can't fail in the same way.
Re: T1 overhaul
Postby Adrian Harris » Sun Jun 17, 2012 12:45 pm
It might be worth taking a look at Rich Stinchcomb's website, as he details the build of his Tiger, with lots of detail shots of how it went together:
http://one6armor.stinch.com/index.html
Re: T1 overhaul
Postby Mick Coleman » Sun Jun 17, 2012 11:22 pm
Dam not looking good, thank you so much for your help mate. Mark can I please grab the details in relation to these two upgrades?
Armour:
1:6 Challenger 2
1:8 King Tiger
Mick Coleman
Re: T1 overhaul
Postby Armortek » Mon Jun 18, 2012 8:45 am
Mick
If you need info or help from us on specific issues, contact us directly via e-mail. Please do not use the Forum or Facebook.
PreviousNext
Return to Tiger 1
