by Bob Gould » Sat Jun 09, 2012 3:07 pm
Hi Mick
I used 2 lengths of 9.5mm aluminium angle cut to about 5mm shorter than can size. then 1 lenght slightly bigger than 3 can widths.
Then 2 lengths of 10mm flat aluminium to make the frame, one either side of the angle and bent another length of aluminium angle round as the surround.
I filed down the bolts on the reverse side to the same thickness as the flat aluminium (about 1.5mm) for a stand-off. I have just glued it together for size but will bolt it down once i have the shape right (as you can see the surround is a bit skew wiff). I will use a pin sticking out from the hull with split pin for the surround ends so it can be taken off
I had seen a similar system on some historic photos. The cans sit on the angle and are held by the surround strap. Simple but does the job
Bob Gould on Sat Jun 09, 2012 3:13 pm, edited 1 time in total.
