• In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
  • Most users ever online was 371 on Mon Sep 03, 2012 7:49 pm
  • Users browsing this forum: No registered users and 0 guests
Panther
Ultimate Panther/Jagdpanther Build
Re: Ultimate Panther/Jagdpanther Build
Postby michael hilton » Wed May 09, 2012 3:17 pm
Hello Mark, here is the photograph....I have tried all six Hex heads, the 'hex head' binds on the raised dome of the idler cap
michael hilton
Postby michael hilton » Wed May 09, 2012 3:19 pm
Here is the roller....I can adjust this.....thank you, Mick
michael hilton
Postby Armortek » Wed May 09, 2012 3:25 pm
Hi Mick
The idler hub cap in your picture is on back to front (or inside out if you prefer). Just turn it round and everything should fit ok.
Postby michael hilton » Wed May 09, 2012 3:50 pm
Hello Mark.....thank you.....mick :oops:
michael hilton
Postby John Fitzsimons » Thu May 10, 2012 12:44 am
Nice one Mick. If only everything could be so simple. :lol:
If interested in any parts used in my builds contact me at johnfitzsimons@msn.com for a pricelist.
John Fitzsimons
Postby michael hilton » Fri May 11, 2012 5:01 pm
Hello John, yes I agree....why is it that the simple answers are the most difficult to fathom out. Anyway, I guess with the arrival of all those Late Tiger kits, the Forum should be creaking at the seams......lovely.
michael hilton
Postby michael hilton » Fri May 11, 2012 5:11 pm
Fitted the road wheels....my little 'key' proved most useful. It's so much easier to move around, when the tank is on a table lift.
I recessed/chamfered the gear case,so the roller is a close fit to the hull side.
I turned the idler cap around....it fits a treat, now why didn't I think of that :D
michael hilton
Postby phil fitzpatrick » Fri May 11, 2012 9:52 pm
Well done Mick
For sorting your running equipment out,you are doing well.
Thats a nice clean white blanket in your hull,have you just
made your bed up for the night :)
phil fitzpatrick
Postby michael hilton » Sat May 12, 2012 8:47 am
Hello Phil, it's surprising where the dust comes from....so I do try to keep the tank as clean as possible....hence the blanket, could have said it belongs to the cat......only we do not have a cat.
My 'move around' was spotted by.....guess who?
We are soon to be 'swamped' by Tigers.....can your T34 cope?
Best wishes and keep well....Mick
michael hilton
Postby phil fitzpatrick » Sat May 12, 2012 1:50 pm
Hi Mick
You did a nice neat move arround,you are well organised.
My T34-85 will have to cope with the Tigers :)
Cos my Late Tiger is in the garage :D :D :D :D :D :D :D :D :D
phil fitzpatrick
Postby John Fitzsimons » Sun May 13, 2012 1:52 am
It nice to clutter up a room ot two with these babies, i have two in the house at the moment. See padges king tiger built. It's terrible what we put our women through.
John Fitzsimons
Postby michael hilton » Sun May 13, 2012 10:14 am
Hello John....absolutely. My grandson and his partner have just presented me with twin boys.....I always wanted to be a great grandad. :D
Now, Forum members with your vast amount of knowledge....a question. I am fitting the drive sprockets. The sprocket is located firmly on the gear shaft, and is set at 62mm from the hull to the centre line. I have followed the instructions to the letter.
I will attach two photographs...as you may be able to see, the 'roller' is against the sprocket and binds when the sprocket is rotated. So, I need a solution,the roller is firm against the hull.I have questioned whether the roller is on the 'right way round'
michael hilton
Postby michael hilton » Sun May 13, 2012 10:17 am
HImage
Here is the second photograph....
michael hilton
Postby michael hilton » Sun May 13, 2012 10:35 am
Scrub that last question....I have installed the roller, 'the wrong way round'. I seem to make a habit of this.....I'm a wrong way round person..... :) Mick
michael hilton
Postby phil fitzpatrick » Sun May 13, 2012 3:51 pm
Hi Mick
Congratulations on becoming a grandad :)
Well done sorting your little roller problem out,
your build is coming allong great
phil fitzpatrick
PreviousNext
Return to Panther
