• In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
  • Most users ever online was 371 on Mon Sep 03, 2012 7:49 pm
  • Users browsing this forum: No registered users and 0 guests
Tiger 1
Dales mid tiger 1
Postby Dale jordan » Tue Dec 28, 2010 5:16 am
Hi John . I'm glad you are making a start . The turret is a good spot to start ... Your late tiger wrap is the same as mine , but you will have the thicker roof for the late tiger which will sit up higher then the mid tiger .. Dale
Dale jordan
Postby John Fitzsimons » Tue Dec 28, 2010 11:57 pm
Thanks Dale and Tim. I am not such an expert on these little details between mid and late Tigers. That is one thing less to think about. I am going to strip my turret down again and try for a closer fit around the Turret base. Have to sort out my Burst pipes around the house first thanks to freezing weather here.
Thanks Tim for pointing me in the direction of David Grays Gallery. It has answered a lot of my questiond and given me some ideas. I have contacted Steve Winstone regarding a number of his Tiger Items and will add some of these to my build. Not too sure which Hatches to go with. I like detail but at a good price.
John Fitzsimons
Postby Dale jordan » Tue Feb 08, 2011 10:14 pm
Here are some new photos of a bit of work on my turret . I've added all the welds and some of Mikes parts . Dale
Dale jordan
Postby John Fitzsimons » Wed Feb 09, 2011 12:31 am
Looking good Dale. I was working on my turret for the last few days. Started my welds also. I am wondering about the 8 recessed bolt holes on the turret top. How do you work out how to locate the positions. And what size are they? Are you revising the kit periscopes. I might try making my own. Did you decise on a solution to the track hanger problem?
John Fitzsimons
Re: Dales mid tiger 1
Postby Dale jordan » Sat May 05, 2012 5:26 am
I'm back . Here are some update photos of my scratch build turret bin .I just need to add Mikes latches some hinges lids and then all those riverts Dale
Dale jordan
Postby Geoff Pipprell » Sat May 05, 2012 7:04 am
What is the bin made of Dale?
Geoff Pipprell
Postby Adrian Harris » Sat May 05, 2012 2:18 pm
> I'm back
Yay :!: :!:
I take it the summer rush is over :?:
Have you thought of changing the steel mantlet pivots for a non ferrous solution ?
I'm wondering about M10 brass bolts, the a piece of brass bar as the lifting lug in place of the head. The 25mm spacer could be aluminium stock, clearance bored through for the bolt.
Just a thought :?:
[Sd.Kfz 222] [Sd.Kfz 7] [Flak 36] [PzKpfw III] [Stug III] [PzKpfw IV] [PzKpfw VI Early] [PzKpfw VI Mid]
[Sherman M4A3] [Sherman Firefly VC] [M2 Halftrack] [M3 Halftack]
Postby simon_manning » Sat May 05, 2012 4:27 pm
nice to see you back on dale, always a pleasure to follow your builds, regards simon manning.
Postby John Fitzsimons » Sat May 05, 2012 9:21 pm
Great to see this build continuing.
If interested in any parts used in my builds contact me at johnfitzsimons@msn.com for a pricelist.
John Fitzsimons
Postby Geoff Pipprell » Mon May 07, 2012 9:58 am
Hi Dale,
Does the original kit come with a turret bin - just wondering why the scratch built turret bin?
Geoff Pipprell
Postby Derek Attree » Mon May 07, 2012 5:48 pm
Hi Dale
Welcome back mate nice work as normal
Derek Attree
Postby Dale jordan » Thu May 10, 2012 8:42 am
Today I added all the riverts plus the two lids and four hinges . Next I'll add Mikes outer latchs then prime ...Dale
Dale jordan
Postby Geoff Pipprell » Thu May 10, 2012 9:42 am
The bins look fantastic Dale.
Geoff Pipprell
Postby John Fitzsimons » Thu May 10, 2012 10:11 am
Looks great Dale. What did you make it from.
Geoff the kit comes with what makes up a very basic bin. Lacks detail. If you are building a tiger and want a detailed bin Steve Winstone does a brilliant upgrade to the kit parts. If you have the skill you could make one like Dale's
John Fitzsimons
Postby Dale jordan » Thu May 10, 2012 10:24 am
Hello Geoff and John I made up cardboard templates then used fibreglass sheets lots of work ! but worth it in the end I'm just wondering if some of the other tiger 1 builders on the forum added the lower turret bin holders I have not seen this detailed talked about on the forum much ? Dale
Geoff here is a link to the one I built in 2008
viewtopic.php?f=6&t=481
Dale jordan
PreviousNext
Return to Tiger 1
