Found: Full set of Panther Tracks
Marco Peter
Has liked: 173 times
Been Liked: 259 times
Post by Marco Peter » Tue Feb 18, 2020 9:41 am
Hi there,
I'm looking for a full set of Panther Tracks.
Mine are pretty worn down and break every now and then.
Don't look at he colors, I'm repainting him, only the turret is done!
'Konan', my Tiger 1 Mid!
'Gunther', my Panther G!
Gerhard Michel
Been Liked: 78 times
Re: Wanted: Full set of Panther Tracks
Post by Gerhard Michel » Tue Feb 18, 2020 10:06 am
Hi Marco,
first of all: wonderful; a tank that may roll in heavy grounds, like tanks have to do that! :mrgreen:
I tried to solve the problem of breaking tracks under load at my Jagdpanther with Vincent's steel tracks, because I have best experiences with Olaf's steel tracks on Königstiger and Jagdtiger. Unfortunately the Panther models are nearly not drivable with these tracks, and the tracks cause ugly damage to the drive train surface. We broadened the sprockets and grinded down the chevrons, but we had no success.
Gerhard
Marco Peter
Post by Marco Peter » Tue Feb 18, 2020 10:09 am
Hmmm thanks for the reply.
Are you trying to say new tracks will break too?
Has liked: 198 times
Been Liked: 307 times
Post by Adrian Harris » Tue Feb 18, 2020 11:22 am
These models have very powerful motors, so are quite capable of breaking track links if the running gear is clogged up with earth, stones or sand.
Much better to drive to the conditions than to expect the tank to chew through everything it encounters.
Steen Vøler
Has liked: 29 times
Been Liked: 133 times
Post by Steen Vøler » Tue Feb 18, 2020 2:16 pm
My JagdPanther did breake some links now and then, but I also did drive in very challenging environments.
https://www.youtube.com/watch?v=_oLY4FO ... 4klDGi421D
look at 08:34 - I was in a pond, so both the jagdpanther and I godt a bit wet changing the track link :D
Field repair at its best
cheers
Steen
www.panzerteam.dk
Marco Peter
Post by Marco Peter » Tue Feb 18, 2020 2:49 pm
Lot's of famous faces around that timestamp but no JP haha!
Gerhard Michel
Post by Gerhard Michel » Tue Feb 18, 2020 3:09 pm
Well, in the 10 years that Hausen Tank Meeting exists, there was no year without a break of an Armortek track link, though there are mown meadows only, but some ascents.
Armortek track links are built very prototypical and true to scale, but are made of aluminium instead of steel. Along with the strong motors a little obstacle suffices to break a track link.
Other manufacturers have otherwise solutions to avoid breaking track links; e.g. thicker links and thinner pins. This gives more durability, but is not true to scale. Another solution is a true-to-scale-track made of brass or ZAMAK.
Gerhard
Gerhard Michel
Post by Gerhard Michel » Tue Feb 18, 2020 3:49 pm
I would think that sand (also if wet) is a rather common condition for a tank (model), though it is a litte ambitious for the drive train. Please see my King Tiger (sorry for the non AT model) after going through a hairpin turn in wet sand. OK, these are a little bad conditions (there are up to 40 mm of sand between track links and drive train), but the KT had no trouble with this condition. Driving straight forward over wet sand should be no problem for a tank!
This model uses Olaf's steel track links which originally were made for Armortek models.
Gerhard
Christoffer Ahlfors
Has liked: 228 times
Been Liked: 71 times
Post by Christoffer Ahlfors » Tue Feb 18, 2020 7:38 pm
In the ten years I have had my tiger 1, I have broken a track link ONCE. I will bet that I will make it through this year's Hausen event without breaking one. If not, I will be happy to buy you a beer! Bets are on! :D
Klotzen, nicht kleckern (Guderian on panzer tactics, but the way I interpret it - it applies to a great many things in life)
Gerhard Michel
Post by Gerhard Michel » Tue Feb 18, 2020 11:15 pm
Hi Christoffer,
I wish you a long life of your track links, because I don't like alcoholic drinks! :mrgreen:
Hi guys,
please keep in mind that in Hausen about 10 to 20 AT models are rolling for hours. In summary this is a lot of operations in a short time. I tried to find out under which circumstances the fractures happened. May be a big part was caused by tracks climbing over the sprockets or the idlers, occuring when driving lateral at a hillside or cornering
Gerhard
Marco Peter
Post by Marco Peter » Tue Feb 18, 2020 11:23 pm
Well I don't own my Tiger for 10 years (yet) but I've never broken a track ever - and I did some crazy stuff haha!
Marco Peter
Post by Marco Peter » Tue Feb 18, 2020 11:36 pm
Since we are having a nice conversation about breaking tracks: the exact moment of breaking the tracks (and why, probably) was caught on film by a bystander!
https://youtu.be/svAMhroGIc8
Marco Peter
Re: Found: Full set of Panther Tracks
Post by Marco Peter » Wed Feb 19, 2020 8:12 pm
I love this forum: only hours after I posted this request I found my set of tracks! :D
Gerhard Michel
Post by Gerhard Michel » Wed Feb 19, 2020 9:45 pm
I tried to mark the possible point of damage just before final breaking down:
Gerhard
Marco Peter
Post by Marco Peter » Thu Feb 20, 2020 10:35 am
Yes I saw that too, looks like one of the newer tracks, but closer inspection showed it was a new track that cracked...
cron
