2016 Armortek audio system speaker question
John Grima
Been Liked: 6 times
Post by John Grima » Thu Jun 22, 2017 7:33 pm
While working on two tigers (an 2004, and 2016 early) Both of these models are using the current 2016 audio / electric motion package. I see on the module that there are only outputs for one speaker. Is this system designed for one speaker, or are the two speakers patched into the same output?
I.E. Red to Red, Black to Black?
yves mouton
Been Liked: 38 times
Re: 2016 Armortek audio system speaker question
Post by yves mouton » Thu Jun 22, 2017 7:49 pm
Hello John,
the wires for the speakers are two pairs of yellow and green ( for both speakers )
Regards Yves
Has liked: 351 times
Been Liked: 733 times
Post by Phil Woollard » Thu Jun 22, 2017 8:46 pm
Hi John , you will need to wire two of the Armortek/Tanoy speakers (or similar ohms value) in series using the single twisted pair, observe the polarity regards Phil
Mechanical engineer, Pyrotechnic technician, and small time farmer.
Email; magpiespyro@hotmail.com
Has liked: 119 times
Been Liked: 189 times
Post by Adrian Harris » Thu Jun 22, 2017 9:31 pm
Both the Benedini and the amplifier are mono, so only one set of speaker connections.
You can wire two in parallel but watch the overall impedance.
R.I.P Margaret I.L.Y
John Grima
Been Liked: 6 times
Post by John Grima » Thu Jun 29, 2017 6:05 pm
Thanks guys, was a great help
yves mouton
Post by yves mouton » Mon Jul 24, 2017 5:12 pm
Hello,
Hi John, i just see that the new Armortek sound module have only
two wires for the speakers, one green and one yellow ( older module have 2 pairs of wires ).
Adrian: so you have to connect the yellow and green wire to one of the speakers?
And put a separate wire between the two speakers ( connect - to - and + to + )
is that correct?
Is that also correct that there are only 2 modules now in the option packs?
I have only the sound and motion mudule.
Regards Yves
Post by Adrian Harris » Tue Jul 25, 2017 12:53 am
Yes
is that correct?
Yes
Yes :-)
yves mouton
Post by yves mouton » Tue Jul 25, 2017 6:54 am
Hello,
Thanks to confirm this Adrian.
regards Yves
