Photographs sideways?
Been Liked: 630 times
Post by Armortek » Sat Nov 17, 2018 12:36 pm
If you are trying to post an image and it is showing up sideways on the forum there is a very simple fix.
1. Open the image on your PC (for example in Windows 10 use the "Photos" program)
2. Make sure the orientation on the screen is correct and make any small change to the image - like crop it or change the brightness/ contrast by a small bit.
3. Save the image and upload that image to the forum. The orientation should now be correct.
Kian
Has liked: 163 times
Been Liked: 272 times
Re: Photographs sideways?
Post by Adrian Harris » Sat Nov 17, 2018 12:41 pm
I find that just using Windows Explorer to rotate an image clockwise and then counter-clockwise works well, even if the image appears to display the right way round as a thumbnail.
R.I.P Margaret I.L.Y
