Q. re Batteries
Pete Mallett
Q. re Batteries
Post by Pete Mallett » Mon Sep 27, 2010 9:12 pm
I was thinking of picking up a couple of these to run the Comet with...
http://www.hardwarexpress.co.uk/csb-gp1 ... -455-p.asp
I might also get a few for my early Tiger 1 which is in the process of being rebuilt. Can anyone comment if these will work OK with the Comet and the Early Tiger 1?
TiA
Pete
PS Will I need one or two per tank? Two I suppose will extend the running time
Has liked: 240 times
Been Liked: 366 times
Post by Adrian Harris » Mon Sep 27, 2010 9:29 pm
Hi Pete.
You'll certainly need two batteries, to give you 24V.
Those that you have listed look a little on the small side to me. I use a pair of 22Ah batteries for the Sherman, which is a similar size to the Comet.
I think the Tiger may benefit from larger still, though I don't have a runner to confirm that.
Ad Wouterse
Post by Ad Wouterse » Mon Sep 27, 2010 10:00 pm
Hi Pete,
You should go for "Deep Cycle" batteries that you can find under the "golf trolley" heading like this one http://www.hardwarexpress.co.uk/golf-ba ... 1683-p.asp and further
Ad
John Davie
Post by John Davie » Tue Sep 28, 2010 1:28 am
Pete,
I agree that deep cycle are the most suitable, I use deep cycle gel batteries in all my models, and I go for the largest that I can fit in the available space (within reason - up to 45ah). I don't know what the Comet will take yet, once I get the option pack in I will see what room is then available.
Pete Mallett
Post by Pete Mallett » Tue Sep 28, 2010 1:22 pm
Thanks for putting me wise guys, much appreciated!
Been Liked: 757 times
Post by Armortek » Thu Sep 30, 2010 6:27 pm
Hi
The recommended battery size for the Comet is the standard 20AmpHour units, as used in the other tanks.
