Martin's Jagdpanther
Martin Hofmann
Has liked: 36 times
Been Liked: 483 times
Re: Martin's Jagdpanther
Post by Martin Hofmann » Tue Sep 26, 2017 6:17 pm
Hi Per,
thank you for the information - yes it is to late - maybe. Do you have some photos of this area? and where do you get your informations, do you have drawings?
Regards Martin
William Gardeniers
Has liked: 9 times
Been Liked: 67 times
Post by William Gardeniers » Wed Sep 27, 2017 7:36 pm
Hello Martin
on this side are some photo's http://www.primeportal.net/tanks/john_g ... gdpanther/
With Regards William
Per Sonnervik
Been Liked: 1 time
Post by Per Sonnervik » Thu Sep 28, 2017 7:38 am
Hi Martin,
I don´t have original drawing of Jagdpanther parts but photos below reveal details; here´s one from the Jagdpanther in Kubinka and as you can see the metal strip is spot welded on and at the arrow (marked 1) you see the outer edge is chamfered to meet the rubber seal:
close up of spot welds;
On the Tiger II´s drivers and MG operator´s hatch the same type of strip is used to hold the rubber seal, this is from an original drawing;
/Per
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Wed Oct 04, 2017 4:43 pm
Hi Kent, William and Per,
thank you very much for the interesting informations, details and photos.
Here are the next photos of the idler wheels with some details.
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Wed Oct 11, 2017 3:59 pm
In the mean time i did some progress on the floor plate - with some holes for the bottom covers. It looks like a cheese from switzerland :lol:
and i start the mounting of the hull......
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Tue Oct 24, 2017 5:53 pm
Here some more photos from the hull and the idler with new threads and the casting surface......
Slowly she looks like a JP....
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Wed Nov 01, 2017 4:48 pm
i have built some more details on the drive housing.
Regards Martin
David Battson
Has liked: 33 times
Been Liked: 28 times
Post by David Battson » Wed Nov 01, 2017 8:41 pm
Hi Martin, Great work on the jagdpanther, lots of nice details.
Just one observation, have you checked that the sprockets won't clash with the drain plugs you've added - it looks very close.
Regards David
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Fri Nov 03, 2017 4:29 pm
Hi David,
thank you for the observation, i had checked the dimensions of the sprocket to the drain plugs - before placing them! :D :D
Here comes the housing with casting numbers and some radii at the adding parts.
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Tue Nov 07, 2017 5:37 pm
After the radii i scratched the surface for Mr. Surfacer to create a casting structure
Regards Martin
Rolf Mönke
Been Liked: 1 time
Post by Rolf Mönke » Wed Nov 08, 2017 9:15 am
sehr schön!!
Greetings from Hamburg
Rolf
bosswilli-hh@gmx.de
Sam Hough
Has liked: 19 times
Been Liked: 8 times
Post by Sam Hough » Wed Nov 08, 2017 10:52 am
Fantastic work!
Been Liked: 115 times
Post by Robert E Morey » Thu Nov 09, 2017 6:41 am
Wow those drive housings look awesome! Great work Martin! I'm loving all the details!
This JP will be superb with those steel tracks.
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Fri Nov 10, 2017 3:40 pm
Hi Rolf,
hi Sam,
hi Bob,
many thanks for the nice words. In the mean time i am working on some parts of the roof. Here are the next photos....
Regards Martin
Martin Hofmann
Has liked: 36 times
Post by Martin Hofmann » Fri Nov 10, 2017 3:49 pm
and here are the next photos.....
Regards Martin
