roadwheels suspension JagdPanther question
Steen Vøler
Has liked: 25 times
Been Liked: 130 times
Post by Steen Vøler » Fri Dec 21, 2012 10:13 am
Hi all
How much space in cm should there be from floor to the JP hull
Have a slight feeling that the roadwheels suspension are a little to weak positioned on my JagdPanther
cheers
Steen
cheers
Steen
www.panzerteam.dk
Bodo Langbehn
Been Liked: 3 times
Re: roadwheels suspension JagdPanther question
Post by Bodo Langbehn » Fri Dec 21, 2012 11:43 am
Hi Steen,
the clearance has to be 93 mm.
Cheers Bodo
Steen Vøler
Has liked: 25 times
Post by Steen Vøler » Fri Dec 21, 2012 12:51 pm
thanks Bodo - wll check this when I get home
If its lower - would I need to change only the strength of the first and last roadwheel or is the advice to adjust all
cheers
Steen
cheers
Steen
www.panzerteam.dk
Bodo Langbehn
Been Liked: 3 times
Post by Bodo Langbehn » Fri Dec 21, 2012 2:20 pm
Hi again,
it depends how big the difference between target/actual-comparison is. I don`t know if the first and last torsionbars are thicker, than the middle torsion bars, what I prefer in my own construction. If the difference isn`t to much, you could try to change the angle only on the first and last two roadwheels each side.
Bodo
Steen Vøler
Has liked: 25 times
Post by Steen Vøler » Sun Dec 23, 2012 10:37 am
Hi,
I measured the space between floor to hull bottom and it is only 5cm, which means that I need to go through some seriously bench work.
As I have not build this model myself, I have a question to the jagdpanther and how to remove the upper hull. Is it bolted from the inside and where do i need to remove bolts to be able to remove the upper hull so that i can get to the front torsionbars adjustments
Thanks for helping out
Steen
cheers
Steen
www.panzerteam.dk
leesellars
Post by leesellars » Sun Dec 23, 2012 11:48 am
Hello Steen
COntact Armortek. They might send a manual out. The top and rear decks are fitted with M3 screws and nuts. To addust the suspension you will have to strip the whole interior out. Tracks and wheels off. Not an afternoon job.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
leesellars
Post by leesellars » Sun Dec 23, 2012 4:38 pm
Hello Steed
I dont know where Bodo has got the 93mm from but that is too high. In my exsperiance the Panther family runs at around the 60mm to 70mm hieght. That is what these models settle down to. This includes the old single and the new twin torsion bar systems.
Lee
