Martin's Jagdpanther
Martin Hofmann
Has liked: 5 times
Been Liked: 78 times
Re: Martin's Jagdpanther
Post by Martin Hofmann » Wed Apr 04, 2018 4:54 pm
Hi Marco,
i use Mr. Surfacer 500 and mix it with some sand from a pet-shop with a diameter of approx. 90 mikrometer. After the first layer there comes two layers with Mr. Surfacer without sand to smooth the surface a little bit.
Here are some new photos from the roof with the covers and the o-rings....
Regards Martin
Been Liked: 75 times
Post by simon_manning » Wed Apr 04, 2018 6:14 pm
nice work, regards simon.
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Tue Apr 17, 2018 5:02 pm
Hi Simon,
many thanks for your compliments.
Here are some more photos of the covers on the roof and the first screws mounted on the Maybach motor!!!
Regards Martin
Marco Peter
Has liked: 60 times
Been Liked: 21 times
Post by Marco Peter » Tue Apr 17, 2018 10:40 pm
Wow!
'Konan', my Armortek Tiger 1 Mid!
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Thu Aug 30, 2018 5:10 pm
Hi Marco,
thank you for your "WOW" :D
after a very long time of doing anything at the Jagdpanther i start again with the next mounting process.
Here are the next photos of the hull and the covers on the bottom and the side. They are all scratch built.
Regards Martin
Been Liked: 46 times
Post by Robert E Morey » Fri Aug 31, 2018 3:49 am
Excellent bump stops and cover plates (on hull bottom).
Looks great!
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Mon Sep 17, 2018 4:23 pm
Hi Bob,
thank you for the nice words. Here are the next covers, the first swing arms and the first welding seams.
I had closed the corners in the sheet over the tracks with another sheet and two srcews. The headlight on the mudguard got a fake cable and some rivets onto the hinges.
Regards Martin
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Tue Sep 25, 2018 3:52 pm
and kilometers of welds.........
Regards Martin
Has liked: 106 times
Been Liked: 30 times
Post by Christoffer Ahlfors » Sun Oct 07, 2018 7:43 pm
Fantastic detail Martin!
You are making progress at a pace like you had nothing else to do, which I know is NOT the case! :shock: Amazing! :D
I hope to see it when ready!
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Mon Oct 08, 2018 4:53 pm
Hi Chris,
thank you for your comment. Yes it works, but not as fast as i would like :D . Here are some more details which are very time consuming. But I have to have these details because I am very in love with details.
Regards Martin
Post by simon_manning » Tue Oct 09, 2018 4:11 pm
lovely work martin, plenty of detail, regards simon.
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Tue Oct 16, 2018 4:50 pm
Hi Simon,
thanks a lot, your comments are very welcome.
Here begins the first step of weathering and aging of the bottom and the side plates, before mounting the swing arms and the wheels.
Regards Martin
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Mon Oct 29, 2018 3:44 pm
In the mean time i prepared the idler wheels and the sprockets for mounting. Also the final drive housing is ready after weathering.
Regards Martin
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Mon Nov 05, 2018 5:04 pm
Now it is time to make some details onto the motor. Here are some photos from this procedure.
Regards Martin
Martin Hofmann
Has liked: 5 times
Post by Martin Hofmann » Tue Nov 06, 2018 5:46 pm
and the next photos............
Regards Martin
