New battery for an old Panther
Maarten Schutjes
Post by Maarten Schutjes » Tue Jul 26, 2016 8:22 pm
After years of service, the 3 batteries of the old 1/6 Panther needed to be replaced. So I decided to use the opportunity to switch to LiFePO. So in stead of using 2x12v for 24 volt and 1x12 volt for 12 volt, I went for 1 x 24volt LiFePo and 1 24/12 converter. It saves a lot of weight and enhances the drive time.
While removing the batteries I found that one was starting to crack. So I consider myself very lucky to have discovered that in time.
I did not rewire everything so the layout is not as neat as it was before. The original layout was done by Mr. Wignall for a previous owner.
Old situation
New situation
Cracked battery
I also replaced the old floor mat with a new rubber mat
Last edited by Maarten Schutjes on Wed Jul 27, 2016 10:51 am, edited 1 time in total.
Peter Silcock
Been Liked: 2 times
Re: New battery for an old Panther
Post by Peter Silcock » Wed Jul 27, 2016 8:37 am
That is strange damage to the battery- never seen this before. I wonder whether the crack is a result of chemical or physical damage. Like the new set up. Can I ask what specification the 24v/12v converter is? With the new set up do you not get feedback through the speakers?
Maarten Schutjes
Post by Maarten Schutjes » Wed Jul 27, 2016 10:49 am
Hi Peter,
I discovered that it's a pressure crack. The battery was tightly strapped on a wooden block that was shorter than the physical size of the battery.
I do no experience any feedback through the speakers.
I used this converter (5 amp)
Between the converter and e the battery I added a power switch. Otherwise the converter very slowly drains the battery when the tanks is not used.
Peter Silcock
Been Liked: 2 times
Post by Peter Silcock » Wed Jul 27, 2016 11:06 am
Thanks Maarten that's interesting about the battery and the converter.
